Hello LTT community!
I'm building my first gaming Pc. I asked the community about my parts and other than the psu and the cpu they said it was fine. Could you tell me if https://www.newegg.ca/Product/Product.aspx?Item=N82E16817151074&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID= this psu is OK for a Intel BX80677I57500 7th Gen Core Desktop Processor and this MSI Radeon RX 480 DirectX 12 RX 480 GAMING X 4G 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support ATX Video Card.
Thanks for the help!
https://linustechtips.com/topic/748139-power-supply-questions/
You can get the 620w version of that from NCIXUS for the same price right now
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/748139-power-supply-questions/#findComment-9473494
Yeah, that pairs with the GPU well.
https://linustechtips.com/topic/748139-power-supply-questions/#findComment-9473562
