Hi,
so I plan to upgrade to watercooling to reduce noise and get lower temps for some OC. I know that my CPU for now will not be overclockable but I will buy a new one in the next months once the price has fallen a bit more. I will use it for gaming/office on at least one 4K monitor plus another 1080p monitor(will maybe upgrade to a second 4k sometime). I also think about buying a second GTX 1080 that should also be included in the water cooling loop. So the radiators should be able to handle the heat from CPU + 2 GPU. I want the system to be pretty silent, which is why I did not go for the high static F series fans. Will the 2x360 rads be enough to have a silent system? I also really like the case because the motherboard is aligned horizontally.
I have had a water cooling kit a few years ago so I am not completely unexperienced however I have no idea about fittings sizes and so on.
I have made the following list of parts that I have/need. Thinks without pricetag are already in my current system:
What I have:
  • PSU                       Corsair RM1000X
  • Storage                  Some SSDs
  • GPU                       Palit GTX 1080 GameRock
  • Motherboard          Asus z170-a
  • CPU                       i7 6700
What I buy:
The prices are straight from the vendor websites so I might get them cheaper, I know. This is just for planning for now.
Will this work out?
Did I forget something and are there better alternatives?
Will the pump+res work with the two 2 360 radiators?
I know that GPU and CPU prices will probably fall in the next weeks, which is why I will stay with the parts I have for now and add them later.
https://linustechtips.com/topic/747236-water-cooling-setup-is-it-enough/
29 minutes ago, Azrael2k8 said:
CPU                       i7 6700
If you are water cooling and getting a Z170 chipset MBO, you might as well as get the i7-6700K. If the CPU doesnt have the "K" at the end, you won't be able to overclock
1 hour ago, wilamu said:
Yea you mentioned overclocking, if you're CPU doesn't have the on the end you won't be able to OC it.
Thanks for the replies but as I stated before, everything without a pricetag is something I already own and plan to upgrade the CPU/GPU in the future. So I already own the 6700 from my previous air cooled setup and am aware that it cannot be overclocked. I will eventually switch to 7700K in the future once the price drop has arrvied at the resellers but for now I want to upgrade the cooling first since that alone is a big pile of money. I edtited the first post to make this more clear.
Are the radiators enough for the tdp (451W) of 2 x 180W of gtx 1080 plus the 91W for probably an 7700k?
Can the pump handle those radiators?
Will the system be silent or do I need to add more radiators?
Are the fans fine for silent operation?
