Hey
Just built a new system inside of a thermaltake core P3 I am using the pci Riser cable so I can mount my video card vertically I have the new rx460 installed and when I turn on the system my TV says no signal so I swapped it out for my old video card and it works fine
I'm thinking it's the video card not to PCi extension cable  what do you think it is very difficult to install the graphics card into the motherboard without the Riser cable because of the way this case is built I would have to disassemble a whole bunch of it to get the graphics card into the PCI slot on the motherboard so I was hoping we couldn't narrow it down without doing that
By the way the fans spin up on the Rx 460  just my TV says no signal
 like I like I said it works fine with my old video card but not with the new rx460 I am using HDMI out to my television
https://linustechtips.com/topic/745497-problem-with-rx-460-please-help/
I know you don't want to here this but I would try to install the card without the adapter. This will tell you either the card is busted or the adapter. It could be a power issue but you said the fans turn on so that shouldn't be it
CPU- Ryzen 9 3900x
CPU Cooler- Artic Liquid Freezer 2 240mm
GPU-  GIGABYTE AORUS GeForce RTX 3070 Ti Master 8G
RAM- CORSAIR VENGEANCE RGB PRO 32GB 3200Mhz
PSU- Cooler Master MasterWatt 650 Watt
HDD- WD Blue 4TB x2
SSD- 1TB WD Blue SN550 NVMe
Case- Custom Made Desk
Motherboard- ASUS ROG Strix B450-F Gaming
Microphone- Blue Snowball Ice
Headphones- Razer Nari Ultimate
Webcam- Logitech c270
Monitors- MSI Optix MAG24C and Acer KA240HQ Abid
Mouse- Corsair Nightsword RGB
Keyboard- Corsair K95 RGB Platinum MX Speed
That's exactly what I did. And it works. There is tons of information online about the occluded PCI Riser cables being bad and having to get replacements you would think after a couple years and thermaltake would fix it I mean that's really the whole point behind this case is to Showcase your graphics card
 it's just odd how the older HD 5850 works with the Riser cable but not the rx460 already got in touch with thermaltake and filled out their application to receive a new one can anyone suggest a decent priced one online
