How do I find the source of my crashes. The past two days, my system has locked up without error or  BSOD while using a flash application in chrome (pearson's myit lab). I also reenabled things for start on windows. Could this cause an issue? Is there a way to find the source of my system lock ups?
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
https://linustechtips.com/topic/745438-system-lock-up/
I'd try WhoCrashed by Resplendence which should pull out some BSOD errors, even if you do not get them on your monitor there might still be some logs left over which it can pick up.
Let me know if you have any results, what the error is and we can try figuring something out.
Read my guide about malware removal here!
If I do not follow your thread, please quote me, tag me or PM me :)
https://linustechtips.com/topic/745438-system-lock-up/#findComment-9466893
I figured it out. It was my nvidia drivers causing the issue. Ended up doing a clean install though because of other odd issues (made the mistake of not reinstalling windows when swapping out my bad mobo)
https://linustechtips.com/topic/745438-system-lock-up/#findComment-9468900
