SSD Help
By
HorseMonkey13
in Storage Devices
in Storage Devices
Solved by jared404,
1. Having an ssd in general will greatly improve your build. Sandisk makes ok ssds but you could get better if you spent a little more
2. Your motherboard should have come with sata cables. Any sata cable will do
3. I think 120gb is good for a budget build
4. If you are on a budget I would just get good double sided tape ssds don't care how they are treated lol
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
