So i was wondering if i use the "wget" command and save it to a specific directory like a NAS would the data be first stored on my comp then transferred or just transferred. I only have an 8gb sd card on my raspberry pi and i needed to download lots of anime from a few websites to my NAS. I was planning to make a script or a list of all the links by using  "$ wget https://www.link.com/something{1-15} -O /my_nas_directory". Could i do this or would it not work at all?
https://linustechtips.com/topic/744431-i-need-help-with-linux/
Ahh, the world of linux. See, in this community, it's a lot less talking and more RTFMing.
I think the best way to learn linux, is to try it yourself.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/744431-i-need-help-with-linux/#findComment-9431820
1 minute ago, Steeve said:
Lol ill try.
Oh shoot, forgot to add on the rest of my answer. Anyways here it is:
Since you're on a forum, I'm going to assume you have already tried. Bundled with Jessie, is Python.
Here would be my workflow in your situation (though don't actually know how to program Python; languages without semicolons kill me):
  1. Get the program to accept a base link
  2. Get the program to accept the largest numbers/range of numbers
  3. Use a for loop to print "commands" (wget www.link.com) into a .sh file
  4. Use this to make your .sh file executable
  5. Profit
https://linustechtips.com/topic/744431-i-need-help-with-linux/#findComment-9431883
  5. Profit
u are a legend thank you man
https://linustechtips.com/topic/744431-i-need-help-with-linux/#findComment-9431885
Am I as good as theLegend27?
https://linustechtips.com/topic/744431-i-need-help-with-linux/#findComment-9431892
steeve did you get this to work?
heres an alternative (assuming you have lynx installed)
user@host:~$ lynx -listonly -dump -nonumbers [your site here]  |grep http |[further filtering here such as grep mp4] >files.txt
then a while loop (bash)
user@host:~$ while read line;do wget <options> $line <any other options> ;done <files.txt
 note: [] used in the lynx command to avoid confusion with the redirect (>) to a file .
sample output of the lynx command above to stdout :
user@host:~$ lynx -listonly -dump -nonumbers www.google.com |grep http
http://www.google.com/imghp?hl=en&tab=wi
http://maps.google.com/maps?hl=en&tab=wl
https://play.google.com/?hl=en&tab=w8
http://www.youtube.com/?tab=w1
http://news.google.com/nwshp?hl=en&tab=wn
https://mail.google.com/mail/?tab=wm
https://drive.google.com/?tab=wo
and more
https://linustechtips.com/topic/744431-i-need-help-with-linux/#findComment-9451277
