3 minutes ago, Kimchi7 said:
AMD AM3 Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
any Gpu
suggest the best name of gpu can i use..because this is my first build but i dont have much money so i spend on old part that cheap on price nowaday, suggest me gpu the best, im not hard gamers.
https://linustechtips.com/topic/744013-help-me/#findComment-9427230
2 minutes ago, deXxterlab97 said:
What psu do u have? Maybe a 1050 or 1050ti for gpu
my psu 500w only, can it support any upgrade gpu? what gpu can comptible with that 500w psu? now i using cpu AMD ATHLON 2 X2, RAM DDR3 4GB
https://linustechtips.com/topic/744013-help-me/#findComment-9427251
