Cᴜʀʀᴇɴᴛ Cᴏᴍᴘᴜᴛᴇʀ:
Cᴀsᴇ: Cᴏʀsᴀɪʀ Cᴀʀʙɪᴅᴇ 270R Cᴀsᴇ ᴡɪᴛʜ Wɪɴᴅᴏᴡ
ᴄᴏᴏʟɪɴɢ: Cᴏᴏʟᴇʀ Mᴀsᴛᴇʀ Hʏᴘᴇʀ 212 LED Tᴜʀʙᴏ CPU Cᴏᴏʟᴇʀ Rᴇᴅ Cᴏᴠᴇʀ
Cᴘᴜ: Iɴᴛᴇʟ Cᴏʀᴇ I5 7600K
Mᴏᴛʜᴇʀ Bᴏᴀʀᴅ: ASRᴏᴄᴋ B250 Gᴀᴍɪɴɢ K4 Mᴏᴛʜᴇʀʙᴏᴀʀᴅ
Rᴀᴍ: Cᴏʀsᴀɪʀ Vᴇɴɢᴇᴀɴᴄᴇ LPX (2400ᴍʜᴢ) 8GB (4x4GB) DDR4 Rᴇᴅ
Gᴘᴜ: Gɪɢᴀʙʏᴛᴇ GᴇFᴏʀᴄᴇ GTX 1050 Tɪ Wɪɴᴅꜰᴏʀᴄᴇ OC 4GB
Ssᴅ: Samsung 960 EVO NVMe M.2 250GB SSD
Hᴅᴅ: Wᴇsᴛᴇʀɴ Dɪɢɪᴛᴀʟ WD Bʟᴀᴄᴋ 1TB WD1003FZEX
Psᴜ: Tʜᴇʀᴍᴀʟᴛᴀᴋᴇ Sᴍᴀʀᴛ Pʀᴏ RGB 750W Bʀᴏɴᴢᴇ Fᴜʟʟʏ Mᴏᴅᴜʟᴀʀ Pᴏᴡᴇʀ Sᴜᴘᴘʟʏ
ɪᴏs: Mɪᴄʀᴏsᴏꜰᴛ Wɪɴᴅᴏᴡs 10 Hᴏᴍᴇ 64ʙɪᴛ OEM DVD
https://linustechtips.com/topic/743914-sleeved-cables/
Idk cause last time I bought sleeved cables, some of the cables didnt actually fit in the PSU
Cᴜʀʀᴇɴᴛ Cᴏᴍᴘᴜᴛᴇʀ:
https://linustechtips.com/topic/743914-sleeved-cables/#findComment-9426149
On the second one it says:
Note: Please check the CableMod compatibility page to confirm if this will be suitable for your power supply here.
the V850 seems to be supported
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/743914-sleeved-cables/#findComment-9426160
