I have had so many issues with my network lately. I have two modems. One is for phone, and one is for internet. The internet unit is connected to a router (ASUS RT-56R) which provides most of the Wi-Fi coverage for the house. My house is a bit large, so we have a range extender in our bonus room (other side of house, 1 floor up). This provides more Wi-Fi coverage and gives me ethernet access through a small switch for my server and my gaming rig. Today the internet has been really slow, both through Wi-Fi and ethernet from the range extender and Wi-Fi on the main router. However the ethernet on the main router is fine. 200/20 all the way. Why would this happen?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/743698-i-need-help-with-my-network/
Have you ever tried a powerline solution?
CPU: Intel Core i5 4690K @ 4.6Ghz CPU Cooler: Noctua NH-D15 GPU: GTX 1070 TI RAM: Crucial Ballistix Tactical 16GB (4x4) Mobo: ASUS Z97-PRO(Wi-Fi ac) PSU: Corsair RM Series RM750 Case: Fractal Design Define R4 no window
Doesn't work good for me. I pay for 200/20 and PL gets 12/18.
Main System: Phobos
Which PL set did you get?
TP Link AV 500 or something like that. It's spanning across different circuits, so I'm not surprised.
Main System: Phobos
That's a shame. And running a physical wire is not an option? You could go linus style and run it outside the house if you can't drill a hole :D. But other than that I can't directly tink of anything else you can try. If you can't run a wire, and wireless doesn' cut it, you don't have much choice but to move your pc.
Does the room the router is in have a coaxial cable in it that'd be normally used for TV? If so and the room with the range extender has one as well then you could always give MoCA a try.
Here is some info about it if you want to read up on it:
http://www.mocalliance.org/about/faqs.htm
It does have a cable line run to it, but MoCA is quite expensive. Is there a budget option for MoCA?
Main System: Phobos
For a set of two adapters it runs ~$130
https://www.amazon.com/Actiontec-MoCA-Ethernet-Adapter-ECB6000K02/dp/B013J7L6BW
I mean what are your other options? Run Ethernet cable to the room itself? Get a router with longer wifi range? You'll spend about the same to be honest lol.
Yeah, that's too much for me. I'm going to investigate running a CAT6 cable around the outside of the house, but we don't really have much of an entrance into the room, and no attic above. Thanks though!
Main System: Phobos
Oh come on now, I thought you were used to buying Apple products ;)
I don't have many Apple products (That translates to 2 iBook G4s, 4 iMac G3s, an iMac G4, a PowerBook G4, a PowerBook G4, a 2008 MacBook Air, and an AirPort Extreme that I recently blew up on accident).
Main System: Phobos
I'm just giving you crap xD
How did you manage to blow up the AirPort Extreme lol?
Wrong power adapter. I didn't get the official one (bought used at a thrift store), and I thought it was the same one as I used the night before.
Main System: Phobos
Ouch, tough luck. Hopefully you get your network woes sorted out!
Thanks. The modem were only using for phone supports MoCA so I may be able to use it with one adapter for upstairs only.
Main System: Phobos
Check to see which version of MoCA it supports. The different versions have vastly different maximum speeds.
Here is what I was able to find on Wikipedia:
