Posted February 25, 2017 Did your first PC build POST the first time you turned it on? Mine didn't, I went to turn it on and the lights and fans came on but there was nothing on the screen! I decided to read the motherboard manual and I found out that the yellow light means there is a problem with the DRAM. I think that my poor cable management knocked one of the sticks of ram out! Link to comment https://linustechtips.com/topic/743361-first-pc-build/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 25, 2017 what do you mean post? CPU - i7-4790k GPU - MSI 980 Ti Mobo - MSI Z97 Gaming 5 Memory - 32 GB DDR3 Storage - 3.4 TB Full List : https://pcpartpicker.com/list/sPgN8d Link to comment https://linustechtips.com/topic/743361-first-pc-build/#findComment-9420818 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 25, 2017 Author 1 minute ago, xDylanio said: what do you mean post? Show the BIOS screen Link to comment https://linustechtips.com/topic/743361-first-pc-build/#findComment-9420824 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 25, 2017 1 minute ago, xDylanio said: what do you mean post? Turn on, in a nutshell. Quote me to see my reply! SPECS: CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones: Sennheiser HD598SE and Sony Linkbuds Link to comment https://linustechtips.com/topic/743361-first-pc-build/#findComment-9420825 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 25, 2017 10 minutes ago, xDylanio said: what do you mean post? POST (Power-On Self Test) https://en.wikipedia.org/wiki/Power-on_self-test Link to comment https://linustechtips.com/topic/743361-first-pc-build/#findComment-9420860 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 25, 2017 No, because I was 12 and had no clue what I was doing. I was sitting Indian fashion using carpet as a test bench. I did eventually get it working. How, I have no clue, I didn't know what the hell I was doing. i7 2600k @ 5GHz 1.49v - EVGA GTX 1070 ACX 3.0 - 16GB DDR3 2000MHz Corsair Vengence Asus p8z77-v lk - 480GB Samsung 870 EVO w/ W10 LTSC - 2x1TB HDD storage - 240GB SATA SSD w/ W7 - EVGA 650w 80+G G2 3x 1080p 60hz Viewsonic LCDs, 1 glorious Dell CRT running at anywhere from 60hz to 120hz Model M w/ Soarer's adapter - Logitch g502 - Audio-Techinca M20X - Cambridge SoundWorks speakers w/ woofer Link to comment https://linustechtips.com/topic/743361-first-pc-build/#findComment-9421444 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 25, 2017 Mine didn't POST due to one of the RAM sticks being faulty. First, I tested my PSU using "paper clip test," and it seemed fine. I couldn't afford another CPU or motherboard, so I hoped it was faulty RAM and ordered a new one. Fortunately, the new one worked, and I was so so happy. Link to comment https://linustechtips.com/topic/743361-first-pc-build/#findComment-9421474 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 25, 2017 Author 3 hours ago, 2Buck said: No, because I was 12 and had no clue what I was doing. I was sitting Indian fashion using carpet as a test bench. I did eventually get it working. How, I have no clue, I didn't know what the hell I was doing. Lol! Link to comment https://linustechtips.com/topic/743361-first-pc-build/#findComment-9421995 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 25, 2017 Author 3 hours ago, Min Ki Jung said: Mine didn't POST due to one of the RAM sticks being faulty. First, I tested my PSU using "paper clip test," and it seemed fine. I couldn't afford another CPU or motherboard, so I hoped it was faulty RAM and ordered a new one. Fortunately, the new one worked, and I was so so happy. Cool, it must have been a great feeling when you got it working! Link to comment https://linustechtips.com/topic/743361-first-pc-build/#findComment-9422000 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
