Should I buy the i7-6700k for 259.99 now or wait and see if there's a better price drop in the next month or two? Microcenter is having a sale on the 6700 and the 7700 but I don't know which to get. The 7700 is 299.99 I'm probably going to get a Z270 board either way.
CPU: Ryzen 7 1800X
CPU Cooler: H100i V2
RAM: Trident Z RGB 16GB 3000MHz Cl 14
Motherboard: ASUS RIG Crosshair VI Hero AM4 ATX motherboard
GPU: 980Ti
PSU: Rm1000x
Storage: Samsung PM961 512 GB m.2 Nvme sad
Storage: 7500 RPM 2 TB Seagate Barracuda Hard drive
Case: 570X RGB (White)
OS: Windows 10 Pro
https://linustechtips.com/topic/743280-need-help-in-build-decision/
9 minutes ago, mathizel said:
Don't buy it. It doesn't feature out of factory RBG on the stock cooler. That means it doesn't perform well.
... Lol, thanks for the answer but not really helpful
CPU: Ryzen 7 1800X
GPU: 980Ti
PSU: Rm1000x
OS: Windows 10 Pro
14 minutes ago, deXxterlab97 said:
Wait for Ryzen benchmarks pretty please?
I don't really need the 16 cores, it's going to be a gaming build. I'd rather speed on 8 threads than more threads.
CPU: Ryzen 7 1800X
GPU: 980Ti
PSU: Rm1000x
OS: Windows 10 Pro
Well it wasn't directly helpfull, but I'd recommend waiting for a bit if you can. Ryzen seems promising and even if you want Intel, you might see a pricedrop soon because of Ryzen. The RGB joke was a reference to the new Ryzen stock coolers.
