Help SPEAKERS NOT SOUNDING
Solved by rhyseyness,
On 2/25/2017 at 7:40 AM, _VOIDNEXUS_ said:
there is only one audio connector if thats what you call it and i cant really cheange the cables sine its attached to the speaker itself. and idk what passive speakers are but this one is a stero speaker
Ah ok, no worries.
In that case the only thing you can really do is try the speakers on another device.
If they work on another device, there's something wrong with the PC.
If they don't, then the speakers will need to be replaced.
Passive speakers are speakers which require an amplifier.
Active speakers (which sounds like what you have) have amplification built in.
Sorry for the late reply, it's been a busy weekend!
Hope this helps ![]()
