In an earlier thread i talked about designing a Dell Mini type PC
I have gotten a small PC components that can fit in a small PC
I do not plan to keep the case as part of the project in favor of a smaller custom case.
I do not plan to go with everything in here, the only sure things are the Mobo and GPU
PCPartPicker part list: https://pcpartpicker.com/list/GgRdtJ
Price breakdown by merchant: https://pcpartpicker.com/list/GgRdtJ/by_merchant/
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor  ($188.75 @ OutletPC)
Motherboard: ASRock H110M-ITX/ac Mini ITX LGA1151 Motherboard  ($69.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($57.88 @ OutletPC)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($43.74 @ B&H)
Video Card: GALAX GeForce GTX 1060 6GB 6GB EX OC White Video Card
Case: Thermaltake Core V1 Mini ITX Tower Case  ($34.99 @ Newegg)
Total: $395.35
Generated by PCPartPicker 2017-02-24 00:27 EST-0500
Tell me where you think I can make it more powerful in the same size or smaller without much sacrifice of performance
https://linustechtips.com/topic/742949-stream-box-top/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($299.99 @ SuperBiiz)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  ($14.99 @ Newegg)
Motherboard: ASRock H170M-ITX/DL Mini ITX LGA1151 Motherboard  ($54.99 @ Newegg)
Memory: Mushkin Essentials 8GB (2 x 4GB) DDR4-2133 Memory  ($49.88 @ OutletPC)
Video Card: XFX Radeon RX 480 8GB XXX OC  Video Card  ($179.99 @ Newegg)
Case: Raidmax Element Mini ITX Desktop Case  ($30.98 @ Newegg)
Power Supply: Corsair CXM 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $734.55
Generated by PCPartPicker 2017-02-24 00:49 EST-0500
This thing is tiny as hell.
GPU is blower style so it may be a little louder but instead of pushing air around the case it pushes it out.
It's the cheapest 480 by a long shot, and it even comes with DOOM for free!
6700 stock cooler is loud as hell, so I picked up a cheap good cooler.
idk
https://linustechtips.com/topic/742949-stream-box-top/#findComment-9416362
