Problem with Radeon Software auto-update.
so, whenever the radeon software tells me there is a new update available, i try to update it trought the software but after asking for permission, it sends an error message about compatibility with 64bits, does this happen to other people with AMD cards? i have to go get it from their website everytime.
https://linustechtips.com/topic/742588-problem-with-radeon-software-auto-update/
Best thing to do if you want to update your GPU drivers is to use Display Driver Uninstaller (DDU). It will completely remove your current driver and reboot. Then you can install the new one you downloaded from the website.
Using the radeon update utility might cause problems or errors, as in your case
Computer Case: NZXT S340 || CPU: AMD Ryzen 5 1600 || Cooler: CM Hyper212 Evo || MoBo: MSI B350 Mortar || RAM Vengeance LPX 2x8GB 3200MHz || PSU: Corsair CX600 || SSD: HyperX Fury 120GB & 240GB || HDD: WD Blue 1TB + 1TB 2.5'' backup drive || GPU: Sapphire Nitro+ RX 580 4GB
Laptop 1 HP x360 13-u113nl
Laptop Lenovo z50-75 with AMD FX-7500 || OS: Windows 10 / Ubuntu 17.04
DSLR Nikon D5300 w/ 18-105mm lens
Yeah thats what I ended up doing. Ty tho.
