1 minute ago, deXxterlab97 said:
Assign mute/push to talk to some keyboard button. Then assign G buttons to that keyboard button. Or autohotkey could somehow do that
you can make the buttons do nearly anything, you could use a passage of the bible as your mute button if you wanted to :D
https://linustechtips.com/topic/741648-logitech-g502-help/#findComment-9401434
wowzers I dont understand. The issue im having is that i can only assign the as mute or back, forward. As when i press that button it will mute teamspeak yes but it will also go back a tab in chrome or mute the song im listening to as well.
https://linustechtips.com/topic/741648-logitech-g502-help/#findComment-9401443
So you need to mute specifically team speak? LGS mutes everything.
https://linustechtips.com/topic/741648-logitech-g502-help/#findComment-9401459
Ok, here me out. is there a way to just set the buttons on the mouse as just macros like the ones that you will find on a keyboard. Ones that dont do anything until you bind them to a game or something. If i unassigned something in the software it will just disable that button. I just want is as a G key or a extra button.
https://linustechtips.com/topic/741648-logitech-g502-help/#findComment-9401476
you can set it to use a macro, which can be quite literally anything you can press :P
and then, you just allocate that as your mute button.
https://linustechtips.com/topic/741648-logitech-g502-help/#findComment-9401479
Check AutoHotKey. I am not really experienced with that. But AHK seems to do everything. There should be some guide or tutorials on how to mute specific programr
https://linustechtips.com/topic/741648-logitech-g502-help/#findComment-9401485
Yeah but then that button will be disabled. So if OP uses F5 as mute team speak he can't use F5 for something else. Waste of a keyboard button
https://linustechtips.com/topic/741648-logitech-g502-help/#findComment-9401491
2 minutes ago, manikyath said:
one button is still a multikey macro, it's just not very multi :D
Im soooo confused. I just want the button to be a g key. Not any of the functions. such as dpi switching or switching to the next track. I see no option to make it just a unassigned button.
https://linustechtips.com/topic/741648-logitech-g502-help/#findComment-9401542
