Hi everyone.
I am currently planning to upgrade my computer from a laptop (Lenovo Y500, i7-3630QM, GF 750M) to a desktop and I'd like your input on a part list I'm in the process of putting together.
I'd like the system to be able to handle games like Witcher 3 and Watch_Dogs 2 at high setting, with ideally a 21:9 100Hz 1440p screen. I also do a bit of CPU and memory intensive work, so it would be nice to not skim too much on theses. I currently have 8GB of RAM and it's already not enough.
I am in Canada with a budget of around 2.5 k$ for everything including new peripherals. I don't mind paying a bit extra for the looks, as you might tell from the part list.
Here's the part list : https://ca.pcpartpicker.com/user/alsimoneau/saved/Mq7sYJ
I might like to change some of the case fans.
Thank you so much !
https://linustechtips.com/topic/741601-first-build-appraisal/
1 minute ago, YaqinHasan said:
I'd personally change the 480GB SATA SSD to a 256GB 960 evo for speed and also get a 7700k since you said you wanted a ore powerful CPu
He probably wouldn't notice the speed difference though.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/741601-first-build-appraisal/#findComment-9400904
1 minute ago, The Physicist said:
The SSH or the CPU ?
I was saying on the SSD.
https://linustechtips.com/topic/741601-first-build-appraisal/#findComment-9400944
A high refresh rate 1440p monitor is going to cost you $500 or more. I would suggest that you choose either a high refresh 1080p or 60 hz 1440p with your budget. Especially since you need a large amount of Ram and a good CPU.
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/741601-first-build-appraisal/#findComment-9400987
I can always upgrade the monitor later. I'd still like the system to handle the load if it comes to that eventually.
https://linustechtips.com/topic/741601-first-build-appraisal/#findComment-9401008
2 minutes ago, The Physicist said:
So the CPU upgrade is worth 150$ then ?
With your budget ya.
https://linustechtips.com/topic/741601-first-build-appraisal/#findComment-9401019
If you're doing things that are CPU intensive an I7 would be a good idea.
https://linustechtips.com/topic/741601-first-build-appraisal/#findComment-9401020
I do have access to a cluster for the heavy workloads,  running some computations in a VM while watching LTT on youtube is a daily task.
The extra threads will be very nice for running a VM.
High refresh monitors kinda suck without Freesync or Gsync anyway. This is probably your best bet.
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($464.75 @ Vuugo)
CPU Cooler: be quiet! Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($95.98 @ DirectCanada)
Motherboard: MSI Z270 TOMAHAWK ATX LGA1151 Motherboard  ($180.48 @ shopRBC)
Memory: G.Skill Ripjaws V Series 32GB (2 x 16GB) DDR4-2133 Memory  ($234.99 @ Newegg Canada)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($222.65 @ Vuugo)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($110.50 @ Vuugo)
Video Card: MSI GeForce GTX 1070 8GB Video Card  ($579.99 @ Newegg Canada)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case  ($95.98 @ DirectCanada)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($79.99 @ Newegg Canada)
Monitor: AOC Q2778VQE 27.0" 2560x1440 60Hz Monitor  ($299.99 @ Memory Express)
Total: $2365.30
Generated by PCPartPicker 2017-02-21 14:10 EST-0500
https://linustechtips.com/topic/741601-first-build-appraisal/#findComment-9401038
Total: $2365.30
Is the air cooler better than the liquid one I had ?
And I'd like to know your reasons for that case, just because I'm not clear of the advantages of any of them beyond the look.
Also I would love a 21:9 screen, but I can wait for that investment as I already have a 27" 1080p 60Hz.
https://linustechtips.com/topic/741601-first-build-appraisal/#findComment-9401065
About on par, I actually put that in there to save some money when I was trying to squeeze in the 144hz monitor.
I love Enthoo cases. This one is especially nice, minimalist and at a very reasonable price point. But the real difference would be where you place your PC. I have it on the desk next to me, so the placement of its I/O is awesome, but the S340 is better for those who put their pc on the floor.
And thats fine for the monitor, I didnt know you had a monitor already since you were coming from a laptop
https://linustechtips.com/topic/741601-first-build-appraisal/#findComment-9401083
Thank you so much !
I should have mentioned the screen, my bad.
I will take all of this into account when I take my final decision !
https://linustechtips.com/topic/741601-first-build-appraisal/#findComment-9401110
  • 3 weeks later...
