Hello, this summer i'm building a pc, for around 1k or so euro.
ofc piece prices will be different by summer, but i'd still like to see what would be the result now.
besides the pc price, i'll look for a monitor or tv for around 600 euro, view distance is 4m
i'm guessing the screen has to be 4K because of the distance, but i'm not sure,
the question is, can i build a pc for 1000 euro and still get 60ish FPS on 4K?
also, what monitors/ tv  would You guys suggest? Currently i have my mind on LG 43UH668V 43'', since i work in A/V Store and this is a well selling model.
Mostly i play WoW, but i really enjoy DayZ and Arma3 aswell.
Besides gaming i do graphic design and animations.
-Chris.
https://linustechtips.com/topic/741472-possible-4k-build/
For 1K€ wont be easy to run 4K...
PCPartPicker part list: https://de.pcpartpicker.com/list/Zxp4wV
Price breakdown by merchant: https://de.pcpartpicker.com/list/Zxp4wV/by_merchant/
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  (€212.05 @ Mindfactory)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€33.08 @ Mindfactory)
Motherboard: ASRock H270 Pro4 ATX LGA1151 Motherboard  (€105.76 @ Mindfactory)
Memory: *Kingston Savage 16GB (2 x 8GB) DDR4-2400 Memory  (€113.71 @ Amazon Deutschland)
Storage: *Silicon Power Silm S55 480GB 2.5" Solid State Drive  (€131.43 @ Amazon Deutschland)
Video Card: Zotac GeForce GTX 1070 8GB Mini Video Card  (€392.25 @ Mindfactory)
Power Supply: *SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  (€82.23 @ Mindfactory)
Total: €1070.51
Generated by PCPartPicker 2017-02-21 15:31 CET+0100
https://linustechtips.com/topic/741472-possible-4k-build/#findComment-9399418
if we combine your pc and monitor budget, 4k is doable.
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  (€310.90 @ Amazon Deutschland)
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  (€52.43 @ Mindfactory)
Memory: Corsair ValueSelect 16GB (1 x 16GB) DDR4-2133 Memory  (€102.89 @ Amazon Deutschland)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive  (€81.03 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€50.56 @ Amazon Deutschland)
Video Card: EVGA GeForce GTX 1080 8GB ACX 3.0 Video Card  (€602.94 @ Mindfactory)
Case: X2 X2-6021B-CE-R ATX Mid Tower Case  (€34.76 @ Amazon Deutschland)
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply  (€48.15 @ Mindfactory)
Monitor: AOC U2879VF 28.0" 3840x2160 60Hz Monitor  (€325.94 @ Mindfactory)
Total: €1609.60
Generated by PCPartPicker 2017-02-21 15:34 CET+0100
https://linustechtips.com/topic/741472-possible-4k-build/#findComment-9399438
