Hi,
I'm trying to increment the following code to line 2 on file2.log, as I would like it to automatically print each line from file1.log, one at a time:
#!/bin/bash
let "LINE++"
( head -1 file2.log
  head -${LINE} file1.log | tail -1
  tail --lines=+2 file2.log
) > file2.new
mv file2.log file2.old
mv file2.new file2.log
How could this be done?
Thank you
https://linustechtips.com/topic/739472-bash-script-increment-a-variable/
So you just want to take the text from the file, line by line, and append this to a log file?
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
2 minutes ago, spbr said:
No, I want to print it into a file onto a specific line.
Does the file already exist, and, if so, does it already contain data?
3 minutes ago, spbr said:
correct
Do you want to replace the contents of that line, or append the data to the end of the line?
22 minutes ago, spbr said:
So within the file I would like to keep:
wireless-key s:
and only replace the password everytime through the loop
Try this:
Use a while loop, which increments $lineNumber each time, until
wc -l file.txt
is reached and then runs
sed -i "$lineNumber s/.*/wireless-key s: $lineContents/" targetFilePath
You won't learn as much if I give you something to copy-paste :)
34 minutes ago, Fetzie said:
Try this:
wc -l file.txt
Thank you
2 hours ago, Fetzie said:
Try this:
wc -l file.txt
Hi,
I'm unsure on what to put in between the while loop brackets:
#!/bin/bash
x=1
while [ $x -le ]
do
        (       head -1 file2.log
                head -${x} file1.log | tail -1
        ) > file2.new
        x=$(( $x + 1  ))
        if ( wc -1 file1.log  )
        then
                sed -i "$x s/.*/wireless-key s: $file1.log/" /etc/network/interfaces
                break
        fi
done
Why not something like:
#!/bin/bash
sourceFile="/path/to/source/file"
targetFile="/etc/network/interfaces"
numLines=$(wc -l ${sourceFile})
counter=0
# exit if file is empty or does not exist, exit
if (( counter >= ${numLines} || ! -f ${sourceFile} )); then
	echo "invalid file"
    exit 0
fi
while [ ${counter} -le ${numLines} ]; do
	sed -i "${lineNumber} s/.*/wireless-key s: $(sed -n ${counter}p <<< "${sourceFile}")/" "${targetFile}"
	counter=$((counter + 1))
done
Haven't run it but it should work. Might need bit bit of tweaking to get exactly what you want.
#!/bin/bash
counter=0
	echo "invalid file"
    exit 0
fi
done
Thank you
On 2/18/2017 at 3:25 PM, Fetzie said:
Huge Thank you on the below
#!/bin/bash
counter=0
	echo "invalid file"
    exit 0
fi
done
1
1
Unfortunately im at an inpass with the below:
sed -i "${lineNumber} s/.*/wireless-key s:" "$(sed -e ${counter}"p <<< "${sourceFile}")" ${targetFile}"
I'm unable to get this line correct so there is no errors, but when there isn't the target file doesn't print the contents of file1.log.
Thank you
7 minutes ago, sgzUk74r3T3BCGmRJ said:
It's unclear to me what you're trying to accomplish. You may get better help by explaining exactly want rather than asking for help doing whatever it is you think is the correct way to solve the problem. It could be that you've settled on the incorrect tools for the task and so asking for help banging them together is a waste of everyone's time.
Ignoring all of this BASH nonsense for a moment, is it fair to say you have two files?
$ cat foofile
flim
flam
floom
$ cat barfile
bing
bang
bong
Is it also fair to say you want to combine them by inserting the content of `foofile` into `barfile` at some arbitrary line?
$ combine-at-line 2 foofile barfile
flim
bing
bang
bong
flam
floom
If not then please give some examples of your source data and the expected output. Based on the above assumption, what you're describing looks like a job for `cat` and a file descriptor or two.
Hi,
I've got a list of permutations in one file and the program will need to do the following in this order:
  • Take one permutation
  • print to /etc/network/interfaces file, on line 3, in front of 'wireless-key s:'
  • restart the network
  • ping the network 5 times
  • - if successful save the file and print to a file or screen listing the password
  • if not successful restart from the top
Thank you
