if your in the UK i use
https://www.overclockers.co.uk/
they do next day delivery good prices and very helpfull if you have any problems or questions
Specs:
CPU: Intel core i7 6700k (OC 4.6ghz)
CPU Cooler:Corsair H110i GTX
Motherboard: ASUS Z170 Deluxe
RAM: Kingston DDR4 HyperX Fury 16gb (2x 8gb) 2666MHz
GPU:EVGA GTX 980Ti Classified (OC)
Monitor: Acer predator x34, 3440x1440, 100hz
https://linustechtips.com/topic/739107-power-supply-help/#findComment-9375893
20 hours ago, Fallen Dk said:
Tomorrow am getting a Lenovo m91p sff i5 with windows 10 but the sad part I want to upgrade some parts but the power supply is only 240w which is not good because all low profile graphics cards need 300+w any one know where to get one? Like a 400+w for a good price?
A Corsair CX450M would work fine for you. That said, not all discrete GPUs require that much power. You could easily run a 1050ti off your PSU.
https://linustechtips.com/topic/739107-power-supply-help/#findComment-9379907
