i am trying to erase everything from my computer because it seems to be running slow if i decide to boot from the windows disc and re install windows 8 will it delete everything from the hard drive???
System Specs~~~~~
Case-Corsair Air 540                                   CPU-i7 4770k                           Ram-Corsair Vengeance 16 Gbs    PSU-Corsair RM1000
Motherboard-Asus Maximus VI Formula    Graphics-Asus Gtx 780 Ti x2     CPU Cooler-Corsair H100i               SSDs-Corsair Force GS 128/360 Gb
https://linustechtips.com/topic/73786-cleaning-hard-drive/
If you delete the partitions during the installer, it will delete everything.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/73786-cleaning-hard-drive/#findComment-1011047
It will do exactly that. Backup and install windows again. Or just, you know, cleanup unnecessary programs, look at your task manager and figure out which programs are there that you don't want. Also, sort out your boot programs in task manager.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/73786-cleaning-hard-drive/#findComment-1011051
If you do reinstall windows and have a flash drive or a second partition on your hard drive or an external had drive or something I strongly recommend downloading all the drivers for your components as well as getting a ninite installer with everything you need.  Speeds up the set up quite a bit.
First Build:| Gigabyte 990FXa-UD3 | FX 8120 4.0Ghz | Coolermaster Seidon 240M | Asus Radeon HD 7870 | Kingston HyperX 3k 120GB SSD + WD Green 2TB HDD | Corsair RM750 | 8Gb Kingston HyperX 1866Mhz CL9| Fractal Define R4 White/Windowed |
https://linustechtips.com/topic/73786-cleaning-hard-drive/#findComment-1011185
