27 minutes ago, Droidbot said:
VRM temperature. VRMs are what supply the power to the processor, and are not cooled by fans  - but they're built to run hot hot hot. They're a little high, but most boards are built for 100C+.
what abt temp 1,2,3 5,6 why r they low ?only 4 is worrying me i hv noticed now
https://linustechtips.com/topic/736901-motherboard-temperature/#findComment-9351784
1, 2, 3, 5, 6 are all temperature probes around the board. Like PCI-E slots, air temps, etc. They're usually meant to be 30-40C while idling.
4 is VRMs.
idk
https://linustechtips.com/topic/736901-motherboard-temperature/#findComment-9351791
Stick a fan over the VRM's, i got ~20c drop on my old setup - FX-8370 4.7ghz 1.428v on a Sabertooth 990fx 2.0.
Ryzen 3800x 4.4ghz 1.294v all core Noctua NH-D15 x570 Aorus Elite 16gb G.Skill Flare X 3600mhz 15-15-15-30 1T
XFX 5700 XT Thicc III Ultra Seasonic Focus+ 650w Platinum
https://linustechtips.com/topic/736901-motherboard-temperature/#findComment-9352003
