case and cooling help please
Go to solution Solved by Squibbies18,
24 minutes ago, lordofscribblez said:
Will the coolermaster hyper 212 evo fit in the aerocool aero-500 case??? (sorry if under wrong topic, didn't know where to go)
Yes, I fitted one into my friends PC when I built it for him in that case :)
EDIT: I would look into getting a Cyrorig H7 instead though as it is smaller than the 212 evo and will definitely fit in your case without coming close to the side panel
