1 minute ago, fiberzs is dad said:
Sure this is compatible? Are the other things ok?
and the cpu cooler will fit but you could always go with an aio like this http://www.amazon.in/Corsair-Performance-Liquid-CW-9060017-WW-LGA1150/dp/B00SV7IIDU/ref=sr_1_1?s=computers&ie=UTF8&qid=1486651697&sr=1-1&keywords=H80i+GT
3 minutes ago, fiberzs is dad said:
Thank you so much man!!!!!!
@AKV404258 I suggest you get Windows 10 Home from here for 2000 INR and Windows 10 Pro at 2130 INR from here. :)
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
1 minute ago, Freezanator said:
@AKV404258 I suggest you get Windows 10 Home from here for 2000 INR OR Windows 10 Pro at 2130 INR from here. :)
@AKV404258
My Daily Driver:
