Hi all,
Wondering if someone would be able to offer some help with a random problem I've come across. I currently have 2X ASUS Strix 1080's in SLI with the HB Bridge. Now what I've come across is when I swap the cards into different slots they seem to perform much different, which I don't understand why this is happening. I've attached a few screenshots of differences, if someone would be able to assist in this weird problem it would be greatly appreciated.
GPU-Z Sensor Log.txt
CPU: Core i9 9900K @ 5GHz  | Motherboard:  ASUS ROG Maximus XI Hero  GPU: EVGA XC Ultra Geforce RTX 2080Ti RAM: 32GB G.Skill TridantZ DDR4 3600MHz
Storage: Samsung 970 EVO Plus Polaris 2TB M.2 Samsung 970 EVO Polaris 500GB M.2 | PSU: Corsair HX1000i
Case: Phantek Eclipse P600S Glass White | Monitor2X LG 27UD68P Ultra HD 4K IPS
https://linustechtips.com/topic/733684-strix-1080-sli-issue/
Should be runing in 8x each if you have the Strix Z270E i have the same board too but i just run a single 1060 but from my understanding they both run at 8x maybe one is running at 16x?
CPU: Ryzen R7 1700 With Corsair H110i GT GPU: GTX 1060 Strix OC MSI X370 Gaming Pro Carbon 1tb Samsung 850 Evo
https://linustechtips.com/topic/733684-strix-1080-sli-issue/#findComment-9317577
1 hour ago, Generallee said:
Could be thermals, could be PCI-E lanes
Temperatures aren't above 36c - shouldn't be.
Both running 8X. Also, those shots were taken on my X99 system. The cards have come over and the results are the same as the lowest.
https://linustechtips.com/topic/733684-strix-1080-sli-issue/#findComment-9317854
I meant to say I was testing these cards also on my X99 system. It seemed to follow the cards
https://linustechtips.com/topic/733684-strix-1080-sli-issue/#findComment-9317952
Any thoughts on the above?
https://linustechtips.com/topic/733684-strix-1080-sli-issue/#findComment-9328621
