I'm upgrading my friends CPU Cooler, not because it is hot ( Idles 23 c ) but because the fan sounds louder than the security at CES when linus is spotted.
He has a AMD FX 4170, stock cooler, stock speed.
I'm debating between,
https://www.amazon.co.uk/Cooler-Master-Hyper-RR-212E-16PK-R1-Heatpipe/dp/B0068OI7T8/ref=sr_1_1?ie=UTF8&qid=1486253790&sr=8-1&keywords=hyper%2B212&th=1
or
 https://www.amazon.co.uk/Noctua-NH-L9x65-computer-components-Processor/dp/B00UHYDVK0/ref=sr_1_2?ie=UTF8&qid=1486255357&sr=8-2&keywords=noctua+low+profile
Which would you recommended? Will take suggestions as well.
overclocking will happen after this.
https://linustechtips.com/topic/733390-choosing-between-coolers/
I'd say the 212 would be better than the low profile noctua.... but maybe if you're overclocking you could look at something a little more beefy, like the Hyper 412 for £8 more?
https://www.amazon.co.uk/Cooler-Master-RR-H412-13FK-R1-Heatpipe-adapter/dp/B00634R3L6/ref=sr_1_1?ie=UTF8&qid=1486293956&sr=8-1&keywords=hyper+412
https://linustechtips.com/topic/733390-choosing-between-coolers/#findComment-9316031
From those two 212 might be better value. Are you limited to just those two? Why? Pure Rock is £23.22 and would beat 212 in both performance and noise levels.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/733390-choosing-between-coolers/#findComment-9321819
