Hey everyone
Recently I've made my first custom loop:
x99 asus monoblock ekwb
2x 360 slim radiators from darkside
TF-120 fans from deepcool
D5 pump
alphacool res
mayhem pastel white liquid
Fractal design define S
so my block is cooling mobo+cpu (i7-5930k OC 4.5ghz @ 1.29V)
and my idle temps are approx 35C (sometimes 40C) fans at idle are 700rpm (dont like noise) pump 3000 rpm
I feel like thats a little high especially idling, i dont feel like my voltage is anything unreasonable..... attached are some pics if anyone can point out mistakes
Thanks
https://linustechtips.com/topic/732911-high-temps-for-custom-loop/
Ok on first sight I can see air in your block, it needs bleeding, then see how temps are
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
yeah this picture is from a few weeks back the night i finished building it, the air has since left the block and no change to temps!
Did you bleed it? cause if not the air will have just moved into a rad
Ryzen Ram Guide
12 hours ago, danmed said:
I did not, you think that small amount of air will affect cooling alot?
If you didn't bleed it there will be air trapped in a tonne of places. You will need to drop the level slightly and take the res cap off. let it start up and move the case around to free the air out. Also start and stop a lot. Keep tissue around the res incase it "spits"
I would also turn the pump down a little
Ryzen Ram Guide
hmmm that would seem a little troublesome since I wont be able to move the case a lot ( water would spill very quickly)
if my res water levels have dropped about 3cm since the build and have stabilized since... can it be an indication that the build has "bleed itself" ?
in any case ill give it a try
Shake your case a little bit, will help jolt the air out of area's its trapped in.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
Doubt that rad is bled with the ports being on the bottom. I always have to tilt my case quite a bit to bleed mine.
Pump should be easy to turn down. Mine idle at 900-1000. I never see a temp change when turning them up anyway. What program is show those temps?
will do, thanks for the input
your top rad is got a good around of air trap'd and i know the front one is full since i did the same thing put the ports on the bottom . you will end up almost flipping the case to get the air out unless you got very high flow . also run the pump for 12hours+ in one go sometimes extended runs will push it out . the small bubble ant really a problem the larger ones are .
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
real temp GT is the program i use for temps, to properly bleed i need to have the res open right?
alright ill try that, need to make sure res is sealed properly
Just rotate it around while the pumps on max. You can open the res first then turn it to max to elevate some vacuum first. Then close it and proceed to flip the case around.
