I am personally using UnRaid, which supports AFP. I'm pretty sure you should be able to configure it to use spotlight search. As I don't have a Mac I unfortunately can't test it tho.
UI/UX Designer
CPU:
Intel i5 6600k @ 4.4GHz, Noctua NH D-15, GPU: MSI GTX 970, RAM: HyperX Fury 32GB (2x16GB) DDR4, MoBo: AsRock Z170 extreme4 ATX, Storage: 250GB Samsung EVO SSD + 128GB Toshiba M.2 SSD + 1TB WD Blue, PSU: Antec 650W, Fractal Design Define S
