So I'm having a problem with my Ping when i'm playing Games, for example this the game it really affects, I get almost constant lag stuttering, not frame drops but internet issues. However my Ping is constantly in the 20-50ms range. Other things like downloading and browsing the internet is fine but its just games that I have a problem with, I am using a TP-LINK TL-WN851ND 300Mbps Wireless N PCI Adapter.
Many thanks
https://linustechtips.com/topic/732845-internet-ping-problems/
I'd recommend you to check your ping again at speedtest.net. Check it and type it here.
CPU: Ryzen 9 3950X 16-Core | Mainboard: ASUS X570-E Gaming | RAM: Corsair Vengeance Pro RGB 64GB | GPU: Gigabyte Nvidia GeForce RTX 2080 TI | SSD: Segate Firecuda 520 1TB | HDD: All in all 9TB of HDDs | Power: Corsair RM850I | Cooling: Custom Loop | Displays: 3x ASUS ROG Swift PG278Q 1440p 144Hz G-Sync | Keyboard: Razer Blackwidow Chroma V2 | Mouse: Logitech G900 Chaos Spectrum | Case: Fractal Design Define S2 Vision Blackout | OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/732845-internet-ping-problems/#findComment-9309603
2 minutes ago, TehJim said:
That is a very good Ping actually, I'd think it could be a port forwarding issue. Have you set your router to automatically open network ports via UPNP?
https://linustechtips.com/topic/732845-internet-ping-problems/#findComment-9309622
Many thanks
The servers on the game's end may be under heavy load and receiving lots of traffic.
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
https://linustechtips.com/topic/732845-internet-ping-problems/#findComment-9309640
3 minutes ago, TehJim said:
How do I configure that?
I actually don't know how it's done in a different router than the one I have, what kind of router do you own?
https://linustechtips.com/topic/732845-internet-ping-problems/#findComment-9309645
1 minute ago, TehJim said:
That definitely isn't the case since all my games have this problem
I would say it's an issue with the ports on your router. Try turning off things like firewalls and anti-viruses and see if that helps
https://linustechtips.com/topic/732845-internet-ping-problems/#findComment-9309648
Virgin Super Hub 3.0
I'm not from the US, so I can't help you with this specific router but I'm quite sure that the port forwarding is your problem. I had the same problem a couple of years ago when I had an older router that could not properly route ports.
https://linustechtips.com/topic/732845-internet-ping-problems/#findComment-9309670
So I should Port Forward?
https://linustechtips.com/topic/732845-internet-ping-problems/#findComment-9309712
