I'm thinking of building a pc, I need a keyboard and mouse with it, I'm thinking of a Razer Deathadder Chroma for mouse, A Corsair K70 Lux - Red LED and a RazernGoliathus Control XL.  I've made a parts list for myself and I'm not sure if it's a good for gaming or If I should change some parts. I want to spend about €1000 euros total (Pc and keyboard and mouse and mousepad) I live in the Netherlands.
Current parts list I'm thinking of:
-Cpu: Intel core I5 6400
-Motherboard: MSI B150 Gaming M3
-GPU: Gigabyte GTX 1060 G1 gaming 6gb
-Ram: Kingston Hyperx Fury 2 x 4gb ddr4 2133mhz
-CPU Cooler: Cooler Master Hyper 103
-PSU: Corsair VS550
-HDD: 1tb 7200rpm
- Case: Phanteks Eclipse p400s
-Keyboard: Corsair K70 Lux
- Mouse: Razer Deathadder Chroma
- Mousepad: Razer Goliathus Control XL
Is there anything I should change about the build?
https://linustechtips.com/topic/732750-need-help-with-pc-build/
looks good to me
AMD FX 6300 @ 4.6 Ghz CRYORIG H7 Asus M5A97 PLUS | HyperX Fury 8 GB DDR3 | PNY CS1311 120gb SSD WD Blue 1TB 7200 RPM EVGA GeForce GTX 950 Superclocked NZXT Source 210 Black EVGA 500B Logitech G Pro HP K3500 Wireless Keyboard |
https://linustechtips.com/topic/732750-need-help-with-pc-build/#findComment-9308700
1. You don't need a CPU cooler as the stock cooler is more than sufficient
2. Not that PSU...something like the XFX TS 430watt/Proseries Core 450Watt would be much better (or anything from Seasonic, EVGA B2, Corsair CX450M ect.)
3. Cheaper Motherboard and grab a 6500 or even a x2xx motherboard and a Kaby i5
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/732750-need-help-with-pc-build/#findComment-9308719
Should I buy some parts cheaper to get a gtx1070 with it? If yes: Does someone knows what to change to make it cheaper? I've changed the mouse and keyboard to some cheaper ones. The current build I have (with 1070) is:
Cpu: I5 7500
mobo: Gigabyte Ga b250 hd3p
Ram: Crucial Ballistix sport Lt 2x4gb
PSU: Corsair cx550/650m
GPU: Gtx 1070 g1 gaming
Case: Zalman Z11 neo
HDD: WD 1tb
Keyboard: Gamdias Hermes M1 7 Color
Mouse: Steel series rival 300
mousepad: Corsair MM200 extended
https://linustechtips.com/topic/732750-need-help-with-pc-build/#findComment-9322296
