Building a PC for a friends relative, It's used for "Bible studies, taxes, and web browsing/shopping." direct quote from the email.
I've been in contact with them and I also found out that my friend's grandmother hated the way the last one looked as well as performed, so I am tasked with making a great everyday build, as well as an aesthetically pleasing one. Joy.
Their budget is 550 USD max. I'd like to keep it down more if I can. -- Sidenote: Apparently this last prebuilt dell machine was rockin' a Celeron g465 and 6.0 gb of RAM I think. Most anything is gonna be a big upgrade.
Also, they don't need any periphs.
Here's the list:
PCPartPicker part list: https://pcpartpicker.com/list/Y4bKGf
Price breakdown by merchant: https://pcpartpicker.com/list/Y4bKGf/by_merchant/
CPU: Intel Core i3-7100 3.9GHz Dual-Core Processor  ($118.89 @ OutletPC)
CPU Cooler: CRYORIG C7 40.5 CFM CPU Cooler  ($29.99 @ Newegg Marketplace)
Motherboard: ASRock H270M-ITX/ac Mini ITX LGA1151 Motherboard  ($105.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory  ($60.98 @ Newegg)
Storage: ADATA Premier SP550 120GB 2.5" Solid State Drive  ($48.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.33 @ OutletPC)
Case: Phanteks Enthoo EVOLV ITX Mini ITX Tower Case  ($69.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($42.44 @ OutletPC)
Other: OS (windows 10) ($20.00)
Total: $546.50
Generated by PCPartPicker 2017-02-03 13:13 EST-0500
The link is just for good measure. Any suggestions? The OS is gonna be from Kinguin, so that's why the custom part.
Thanks in advance!
Better dead than Red.
Pheonix
CPU: i5 2500k @ 4.6ghz Mobo: Asrock Z77 Extreme4 RAM: G.Skill 16gb of DDR3 @ 1600mhz GPU: Gigabyte GeForce GTX 1060 6gb Extreme Gaming PSU: EVGA 700B Storage: 480GB SP SSD and a 960GB Ultra II Sandisk. Cooler: Cryorig H7 Case: Phanteks P400.
https://linustechtips.com/topic/732715-build-components-suggestions/
1 minute ago, HydraGaming said:
1. Would go with stock cooler to save money.
2. Would get smaller case. Your build should fit into a Fractal Design Node 202 if you replace the PSU with an SFX model (the node 202 has a variant with a decent SFX PSU included).
Believe me, if it was for me, I would do both of those, but I was told that the aesthetic part was that they wanted to see inside the case. Sorry, should've added this to the OP.
Pheonix
2 minutes ago, HydraGaming said:
I had this one originally on the list, doesn't it require a BIOS flash before working with Kaby Lake CPUs?
Pheonix
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($75.00 @ B&H)
CPU Cooler: Enermax ETD-T60-TB 86.7 CFM CPU Cooler  ($29.99 @ Directron)
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2400 Memory  ($51.99 @ Newegg)
Storage: Crucial MX300 525GB 2.5" Solid State Drive  ($139.99 @ Best Buy)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($46.98 @ Newegg)
Total: $519.93
Generated by PCPartPicker 2017-02-03 13:32 EST-0500
Its listed under supported CPU's but i dont know what they mean with "P7.00".
 i3-7100(S0) - Kaby Lake - 3.9GHz - BCLK 100MHz - 3MB - 51W - P7.00" http://www.asrock.com/mb/Intel/H110M-ITXac/?cat=CPU
But i guess its BIOS version, so yeah expect there to be a BIOS update required.
https://pcpartpicker.com/list/3FMVCy
CPU: Intel Pentium G4500 3.5GHz Dual-Core Processor  ($72.65 @ OutletPC)
Motherboard: Gigabyte GA-H110N Mini ITX LGA1151 Motherboard  ($74.99 @ SuperBiiz)
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory  ($50.98 @ Newegg)
Case: Fractal Design Define Nano S Mini ITX Desktop Case  ($52.99 @ NCIX US)
Power Supply: EVGA 450W 80+ Bronze Certified ATX Power Supply  ($37.89 @ OutletPC)
Total: $407.72
