A lot of people on this forum have PSU tier lists. One will probably answer this, but another thing is if you need 550W. Can you send a PCPP link to your build as you might be able to save a couple of bucks if you don't really need 550W :)
Best regards, Mikkel
I disagree. It is far-fetched that you can find a high tier PSU under 500-550W. But the V series is a tier one PSU, so go with that.
That is true. But there's a few bucks difference in 550 and 500, which could save him those $5 for a snack while building it. I don't know, but there might be a 500W model of those above. They are really nice PSU's, you're right :)
When I got my CX550M it was only $4.49 more expensive than EVGA 500B, which is a low tier PSU, so just skip the Cheetos and save yourself the calories (and money, of course)
So you think the V series is more consistent for my build? 550W is more than enough right?
Tier list here:
According to the list you should take the  v550. You will know that is high quality and should last for years.
Allthough it is plenty for your setup it might still be a good one to pick. A small (but no serious) problem with lower wattage PSU is that you have less and sometimes also shorter cables. You might miss certain PCIe connectors for GPU what requires some adapter cabels then to work. Currently I find 500-650 watt range a nice sweetspot in general: it has most of the times all that you need, decent length and reasonable price while still having enough headroom.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
On 03/02/2017 at 10:48 AM, Gonio said:
Tier list here:
And you think 550w is enough to overclock the gpu a bit?
Jup, even a high end system with the x99 platform and a 1080 can run on that with OC.
PSU Tier list
