Hello there, I was playing around in VMWare workstation pro 12. Then I had to turn off my virtual machine and now it wont even boot. I never touched any setting which have anything with this to do, and all the posts I can find online with this problem is people who want to upgrade to windows 10, and I've had windows 10 working without any problems... bear in mind this is on my Laptop not on my primary dekstop, Thank you
https://linustechtips.com/topic/732565-vmware-help/
If it's any help I had this issue once, it was resolved by installing VMware Tools and fully updating Windows 10, I never saw it again after that
Intel i5 6600k @ 4.5GHz | NZXT Kraken X52 | Asus Maximus VIII Hero | Asus ROG Strix GTX 1070 | 16GB DDR4 Corsair Dominator Platinum @ 3200MHz | CoolerMaster MasterCase 5
https://linustechtips.com/topic/732565-vmware-help/#findComment-9306551
Well I had to start again with a fresh install, obviously you can't install VMware Tools if it won't boot :P
https://linustechtips.com/topic/732565-vmware-help/#findComment-9306573
4 minutes ago, myt tech said:
Well, Thank you, I do have a snapshot of the computers though they're linked to the master, and the master doesn't work either :(
TBF I should've stated that in the first place :P
and oh :/ they don't work on your laptop or your desktop?
https://linustechtips.com/topic/732565-vmware-help/#findComment-9306585
Just out of curiosity, is your laptop running on AMD? I have experienced once from a colleague VMware refusing to run VMs on his AMD laptop but the exact install and VM running fine on an intel laptop.
If not then I'm sorry I don't know :(
https://linustechtips.com/topic/732565-vmware-help/#findComment-9306596
Yeah it has an amd a10 but it worked for a couple of days before this started happening.. :(
https://linustechtips.com/topic/732565-vmware-help/#findComment-9306621
Oh :( not a clue then I'm afraid mate, like I say I did that and it worked so I didn't have to look further into it :(
https://linustechtips.com/topic/732565-vmware-help/#findComment-9306628
