hey guys. just building my 1st pc. I got a define r4 as my case.When connecting my power sw connector my mobo info says the pins are positive and negative. How do I know which 1 is positive or negative. Is the red wire positve. There is also an arrow on the power sw connector. What charge does the arrow correspond to. Plz help.
https://linustechtips.com/topic/73204-power-connector-help/
It doesn't really matter which way it goes, but usually the top pin is + and the bottom is -
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/73204-power-connector-help/#findComment-1003131
You're just jumping a connection. Polarity only matters on the LEDs. Regardless, I believe white is positive. Just Google it, and if it doesn't work just flip em.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/73204-power-connector-help/#findComment-1003140
