Ayo,
So my laptops barely over a month old and it's pulling bluescreens on me already! Checking the Event Viewer I see this around the time of the bluescreen. Before the bluescreen, I do get quite a few warnings too. My drivers are up to date as well.
I also find that my keyboard stops responding and then shortly after my touchpad does the same. When my keyboard stops responding it won't register keystrokes or any key bindings, such as Alt + Space to run on Lenovo backlit keyboard, either. About 30 seconds after that my mouse will old go in a vertical direction and favors only 1/3 of the screen. Then 10-15 seconds after that I get a blue screen with POWER_DRIVER_STATE_FAILURE as the Error ID and with the same log in the event as the one above.
How would I overcome this problem?
Thanks,
Duke.
https://linustechtips.com/topic/731948-power-driver-state-failure/
