https://linustechtips.com/topic/731848-led-case-fans/
The fans are probably cheapo and bright as fuck, so yeah, you should be good.
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
https://linustechtips.com/topic/731848-led-case-fans/#findComment-9298024
You should be able to see into the window just fine on both. Worst case, make sure it works perfectly and cut the led off the fans or just replace them if you don't want to cut anything.
"You think your Commodore 64 is really neato! What kind of chip you got in there a Dorito?" -Weird Al Yankovic, All about the pentiums
PC 1(Lenovo S400 laptop):
CPU: i3-3217u
SSD: 120gb Super Cache mSATA SSD
HDD: Random seagate 5400rpm 500gb HDD
RAM: 8GB Crucial DDR3-SODIMM
OS: Windows 10 education
PC 2(2014 Mac Mini):
CPU: i5-4260u
HDD: 5400rpm 500gb
RAM: 4gb DDR3 (soldered on :( )
OS: MacOS Sierra/Windows 10 pro via bootcamp
https://linustechtips.com/topic/731848-led-case-fans/#findComment-9298035
2 hours ago, Splodge1231 said:
ok, thanks guys
No problem. Worst case, case fans are really inexpensive.
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/731848-led-case-fans/#findComment-9298869
