Looking for a better cable modem
Go to solution Solved by GDRRiley,
I am looking for a better cable modem then the xfinity Arris residential gateway
looking for one that has a descent wifi signal and at least 4 ethernet ports for a direct connection to my computers
also needs at least gigabit connection speed for streaming movies to my media room from my office computer
https://linustechtips.com/topic/731678-looking-for-a-better-cable-modem/
that would be 3 diffrent things, do you want a modem or do you want a wireless gateway or wireless router.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
I want a modem with wireless capabilities if there isnt any then a modem and a router that is a good pairing so i can have wifi around my house and the ethernet ports for directly connecting to the modem
6 minutes ago, GDRRiley said:
That will work thanks for the help GDRRiley
