Motherboard Audio Problem?
Whenever my sound gets really loud, there is some crackling from the headset. (I have the RIG 505 Lava) I believe it has something to do with the motherboard because 1. The headset is only a few days old, and 2. It works wonders on my Xbox One.. is there some way to solve it? Even if I put the sound really low, they still have some crackling. It's mainly when it gets loud for the level I set it at. (Basicly if it's really loud, but at 10, it will crackle on loud noises, same on when It's 100, or 50, the numbers is what I set it at for Windows sound.)
PC SPECS
Pentium G4400 (Upgrading to a Kaby Lake Pentium, or i3 soon enough)
Gigabyte H110M-A
8GB DDR4 2133 HyperX Fury Black Ram (1x8)
500GB Hard Drive
Dell OEM Case (Getting a proper case soon)
Dell OEM Power supply (Also.. getting a proper power supply soon..)
https://linustechtips.com/topic/730333-motherboard-audio-problem/
