Entry level audiophile speakers
https://www.amazon.de/Razer-RZ05-01260100-R3G1-Leviathan-Soundbar/dp/B00PHKCZGU/ref=sr_1_5?ie=UTF8&qid=1485422588&sr=8-5&keywords=soundbar+pc
idk what ur budget is but this costs 200€(in germany bit more expensiv so like 180-190$) and its ok
On a budget....
What budget? $10? $10.000?
Do you have an amp? What kind of size speakers are you looking for?
Do you want something new or second hand?
If you want proper advice at least make a little effort when you post a topic.
Does you mum know you're here?
I wouldn't recommend the Razer Leviathan as an audiophile grade system (and that's coming from a huge Razer fanboy - just look at my profile picture). They are decent and I enjoy listening to music on them, but that's it.
As far as actual audiophile gear is concerned, you'll be in for an expencive ride if you want proper stuff
75% of what I say is sarcastic
So is the rest probably
If you can stretch to 500. The Vanatoo transparent 1, would probably be the way to go. They are active speakers, meaning they have an amplifier built in.
The JBL LSR305, is also apparently pretty good for just under 300 usd. These are active as well i believe.
System : I7-6700K EK-Supremacy. . Gigabyte Z170X-UD5 TH . 16GB Kingston HyperX predator ddr4. Evga Supernova 750 G2. Samsung 850 250gb. Samsung 840 250gb.
Evga GTX780 Classified EK-780 Classy . NZXT H440 White. Alphacool ST30 240. HW Labs SR-1 360. Alphacool D5 vario. aquacomputer D5 pump/res combo  . logi G502. CM Quick fire blue.  Dell U2515H.
