Please help a java noob
Go to solution Solved by has246,
hey
try this:
public void chooseloacation() {
sc = new Scanner(System.in);
while (true) {
x = sc.nextInt();
if (x > 0 && x < 7)
    break;
System.out.println("please select a number only from 1 to 6");
if (x == 5) {
System.out.println("poutses");
hey
try this:
while (true) {
x = sc.nextInt();
if (x > 0 && x < 7)
    break;
if (x == 5) {
https://linustechtips.com/topic/728377-please-help-a-java-noob/#findComment-9260879
Firstly, it is helpful to comment out your code more for the end of each bracket. Secondly, try this.x instead of just x. Basically what the former does is say "The variable most in scope". This SHOULD fix the issue, but let me know if I overlooked anything.
https://linustechtips.com/topic/728377-please-help-a-java-noob/#findComment-9260880
to explain.
if you declare a variable inside a loop, its scope will be limited to this loop. Also, if you declared it for the class. just use it inside any method, no need for redeclaring it.Otherwise it will be counted as 2 separate variables.
define it before the loop then you can use it inside the loop and after it in the same method. I advise you to read about variable scope ;)
https://linustechtips.com/topic/728377-please-help-a-java-noob/#findComment-9260885
