CPU Overheating
Go to solution Solved by m0k,
@Jonny24
remove your heatsink,
clean off the old thermal paste from the cpu and heatsink
reapply new thermal paste on the cpu
install the cooler again
and report?
Dear Community,
recently i run a Aida64 stability test and the reults were horrible. After approx. 15 Seconds my CPU started thermal throtteling. Im currently running a RAJINITEK Rhea and have neve expirienced something like this before. Any guesses whats wrong?
thanks in advance,
Jonny
https://linustechtips.com/topic/728068-cpu-overheating/
1 minute ago, manikyath said:
is that on the 4790k listed on your profile?
it may be dust buildup on the cooler, the 4790k doesnt need much dust before towers start to really lack.
Yes it is, but as you mention this, i cleaned it like 4 weeks ago, maybe i messed up something during this
https://linustechtips.com/topic/728068-cpu-overheating/#findComment-9257383
5 minutes ago, Jonny24 said:
Thanks, ill start with this and post an Update afterwards, any tips on thermal paste paste?
because the forum ate my post (i've been relying on the "recover post after refresh" feature too much :P) this will be a bit of a TLDR: you need to use a method that contradicts with what you're scared of doing wrong:
- if you're scared of putting too much, you need a method with which you easily can put too much like the X method, because you'll automaticly try to make the lines in the X as thin as you can.
- if you're scared of putting too little, you need a method with which you can easily put too little like the pea/dot method, because it looks like WAY more thermal paste than it actually is.
- if you're scared of screwing up in general, the "carey holzeman spread" in other words, the buisiness card method, because it is a truly waste of your time, but it guarantees an even coverage. however with your cooler i'd suggest to apply it to the cooler rather than the processor, because of the uneven surface on the cooler.
https://linustechtips.com/topic/728068-cpu-overheating/#findComment-9257433
It's worse to not have enough than having too much. I use the pea size method and go by feel. :) Also your cooler have the locking tabs which I personally hate with passion, so make sure they are open before putting the cooler in and double check if they're locked after the fact.
My modded Air 540 build
https://linustechtips.com/topic/728068-cpu-overheating/#findComment-9257579
I don't get the "pea" sized method. No one ever uses the size of a pea! Peas are bigger than that!
https://linustechtips.com/topic/728068-cpu-overheating/#findComment-9257788
Well it's called pea because it's widely known and just for comparison. I wouldn't overthink it. :)
https://linustechtips.com/topic/728068-cpu-overheating/#findComment-9257800
