Also guys my current psu is cooler master 420w it came with the case, what if i spend more on the rx 480 and not change my psu? can i expect something bad to happen?
4 minutes ago, anybodykek said:
You can play GTA on high at 900p on any half-decent card. You might want to second guess that GPU upgrade, stuttering might be an issue with something else.
7 minutes ago, deXxterlab97 said:
any particular store in pakistan I can check?
19 minutes ago, Hunter06 said:
1. yes it will improve performace..a lot actually...but the current cpu will also heavily bottleneck a 1060.
2. its a entry level psu...it will get the job done
3. 1060 3gb is better than 470 im my opinion...but you can probably get a rx 480 4 gb at a simillar price which is better than both
4. your motherboard is way outdated..no current gen cpu on the market will fit
you should really upgrade if you want to get full performance out of your 1060
5. http://www.wikihow.com/Identify-the-Motherboard
6.  for ports not sure...you have to look into specific 1060 models to find one that supports vga
https://linustechtips.com/topic/727898-need-help-guys/page/2/#findComment-9255395
Which CM exactly? Look at the sticker on the PSU and tell us
https://linustechtips.com/topic/727898-need-help-guys/page/2/#findComment-9255397
2 minutes ago, Extnct said:
no I don't get much stutter in gta v i play on normal preset and get 40~50 fps avg
its with games that require high vram like arkham knight, mankind divided, ac syndicate.
On 900p? Hmm...
Maybe just pick up a used card, because unless you upgrade your monitor an RX 480 will be useless to you.
https://linustechtips.com/topic/727898-need-help-guys/page/2/#findComment-9255398
3 minutes ago, deXxterlab97 said:
Get MSI Afterburner. Setup OSD to have it show in game
https://www.msi.com/blog/setting-up-osd-with-msi-afterburner
thanks for helping me out but Im not on my pc at the momment. I am at a friends house when he told me to consult on this site,
also i don't really think its that good of a psu since i had to downclock my card as every game was crashing
error message = "xxx,xxxx,xxx nvidia drivers stopped responding and recovered"
https://linustechtips.com/topic/727898-need-help-guys/page/2/#findComment-9255444
