So I'm going to be getting a PS4 and will be using my monitor to play my PS4 on. My monitor doesn't have speakers and since there are no analog outputs on the PS4, I'm going to be needing a soundcard that accepts a SPDIF input and outputs it to a 3.5mm headphone jack. (Sorry if that didn't make much since. I'm fairly ignorant when it comes to audio solutions) Somebody has pointed me to the Soundblaster Z, but I was wondering if there was a soundcard that does the same thing at a cheaper price point. I am no audiophile by any means and don't need something that is top notch. Thanks in advance! :)
"You can try to play chess with a pigeon. But even if you win, it'll shit on the board and strut around."
https://linustechtips.com/topic/72696-soundcard-help/
Maybe this isn't helpful, but there is a thread on another forum that may help with your problem.
http://www.head-fi.org/t/572716/need-help-finding-a-cheap-spdif-optical-input-device
Or maybe something like this?
http://www.monoprice.com/Product/?c_id=101&cp_id=10114&cs_id=1011412&p_id=10251&seq=1&format=1#largeimage
It's not a sound card, but an external setup.
Intel i7-3770k @ 4.5 GHz                               DCUII GTX 680                            16GB Corsair Vengeance RAM
Sabertooth Z77 ATX                                      WD Caviar Blue 500GB+ 1TB      Corsair Obsidian 750D
Corsair TX850M Watt PSU                            Bad Custom Water Cooling          Samsung 840 Pro SSD
https://linustechtips.com/topic/72696-soundcard-help/#findComment-995622
https://linustechtips.com/topic/72696-soundcard-help/#findComment-995709
