Python being strange?!?!?!
Go to solution Solved by fizzlesticks,
Your indention is wrong, the line above the if is double indented. The amount you indent doesn't matter but you have to be consistent. Also you need double equals == to compare values and the strings you're comparing to need quotes.
And in the future please use code tags.
I have written this piece of code, its basically a calculator and when i try to run the code in python it give me this error: "unindent does not match any outer indentation level"
it was working before but now it won't work does anyone have any ideas why???
def subtract(first,second):
    print(first-second)
def add(first,second):
    print(first+second)
def divide(first,second):
    print(first/second)
def multiply(first,second):
    print(first*second)
def exponential(first,second):
    print(first**second)
#This is the main program
carryon = False
while not carryon:
        option = input("s to subtract /nor a to add/nor d to divide /nor d to divide /nor e to exponential /nor q to quit")
    if option = s:      <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<*****(THIS IS THE LINE THAT PYTHON DOESN"T LIKE!!!)*****
            one = int(input("Enter a number")
            two = int(input("Enter a second number")
    elif option = a:
            add(first,second)
    elif option = d:
    elif option = m:
    elif option e:
    elif option = q:
                  carryon = True
    else:
                  print("Enter numbers as you have not entered a valid number")
https://linustechtips.com/topic/726860-python-being-strange/
1474412270.2748842
https://linustechtips.com/topic/726860-python-being-strange/#findComment-9243678
