ssd with 1 cable?
Go to solution Solved by W-L,
1 minute ago, Nickmallow said:
i have a prebuilt
the cyberpower ones meant to be changed
In that case as long as the PSU is decent quality you can get a sata splitter like this:
https://www.amazon.com/StarTech-com-PYO2SATA-Power-Splitter-Adapter/dp/B002N2EHVQ
i just bought a samsung 250gb 850evo ssd and i have seen vids of people plugging in a small sata cable but not a small and big one and it still works... i plugged my small sata cable into my ssd and mobo booted and nothing happened. do i need to use 2 cables?  i dont have a wide one
https://linustechtips.com/topic/726733-ssd-with-1-cable/
You do need to use two cables. The wide one connects to the power supply.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/726733-ssd-with-1-cable/#findComment-9242318
You need both sata data (small) and sata power connectors from your PSU.
https://linustechtips.com/topic/726733-ssd-with-1-cable/#findComment-9242327
i have a prebuilt
https://linustechtips.com/topic/726733-ssd-with-1-cable/#findComment-9242358
