So I have been speculating on my pc build for about 1 and a half year and I wanted to ask if my new build will keep me going in the future.
Right now I have my old build:
CPU: Intel i5-4440 3.10GHz Quad core
Motherboard: Gigabyte B85M-D2V
RAM: Crucial (2x4Gb) 1600 MHz 8GB
GPU: MSI GeForce GTX 1060 Gaming 3GB
PSU: Corsair VS 550W ATX
Right now I have a different build:
https://pcpartpicker.com/list/3mQ6yf
I only changed CPU, Motherboard and RAM.
I know that CPU and Motherbaord I have right now is outdated and for 2017 games is just not enough.
My main system purpose is general every day use and gaming. No streaming, no video editing.
https://linustechtips.com/topic/726382-changing-old-gear/
IMO a overclockable CPU might give you more performance but thhat would mean that you have to buy a new mobo+CPU. for the rest the build seems pretty good
Current Build:
CPU: Intel Core i7-7700K at 4.8Ghz CPU Cooler: NZXT Kraken X62 AIO Motherboard: gigabyte Z270X ultra gaming
Memory: Trident Z rgb 16gb 3000Mhz
Storage: Samsung 250GB SSD Storage2: sandisk ultra II 960gb SSD Video Card: Asus GeForce GTX 1080 O8G STRIX
Case: Phanteks ECLIPSE P400
Power Supply: Corsair RM650X Fans: 2x 120mm NZXT Aer rgb LEDcontroller: NZXT Hue+ LEDstrip: cablemod hybrid-LED/UV 60Cm
peripherals:
Keyboard: Razer Blackwidow X Chroma Gamepad: Razer Tartarus Mouse: Razer Mamba TE 2015 Chroma Headphones: Logitech G533 Wireless
Operating System: Microsoft Windows 10 Pro OEM Monitor1: AOC Q2577PWQ 2560X1440 OC'ed to 75 Hz Monitor2: LG 25UM57-P 25.0" 2560x1080 OC'ed to 75Hz
PCpartpicker list: https://pcpartpicker.com/list/Qt76xY
My laptop: https://www.amazon.com/Acer-VN7-571G-50VG-Notebook-Computer-i5-5200U/dp/B01CL50JV6
Quote:
If you really want it, go get it.
https://linustechtips.com/topic/726382-changing-old-gear/#findComment-9239153
don't bother with a cpu+mobo upgrade since you're on haswell, not much of a performance increase from haswell to kabylake. instead, if you want better performance just upgrade your graphics card instead.
https://linustechtips.com/topic/726382-changing-old-gear/#findComment-9241523
