Hello Guys I'm wanting to build my first pc. I already have a pre built pc my parents got it for me as a gift. So I want to build a new 1
1 Budget It's kinda no limit I'm buying parts over time so budget is ok an I'm EAST Coast
2  Aim My aim is to build a new pc to run games for the for seen future
3 Monitors I already have them.
Peripherals I already have them.
5. Why are you upgrading? Because I just feel like upgrading an giving my old parts to a friend his PC got stolen. an I got the HTC Vive for a gift from a friend
6. Here are the parts I'm looking at but I need to know if they will work together
CASE: http://www.corsair.com/en-us/carbide-series-air-540-arctic-white-high-airflow-atx-cube-case
CPU: i7700k
GPU: https://www.amazon.com/dp/B01HSRKJ7Q/ref=twister_B01IUWTLCW?_encoding=UTF8&th=1
RAM: Corsair Dominator Platinum Series 16gb 4x4 sticks
Motherboard: I need helping find 1 that will work
Cooling for CPU: I need help finding something to work with the cpu I want pls help
Power Supply: I already own the power supply its a EVGA SuperNova 850watt B2
Storage: I already have a 500gb ssd an 2tb hard drive
If there is anymore parts I'm missing pls tell me
https://linustechtips.com/topic/725816-help-building-new-pc/
cpu cooler? do you want something watercooled like the corsair nzxt krazen x62? http://pcpartpicker.com/product/bqBrxr/nzxt-kraken-x62-liquid-cpu-cooler-rl-krx62-01
or the corsair H100i v2 http://pcpartpicker.com/product/CrDzK8/corsair-cpu-cooler-cw9060025ww
https://linustechtips.com/topic/725816-help-building-new-pc/#findComment-9232967
since you have a white case, a white themed pc might be a fun thing to do.
for mobo i think the asus PRIMe z270A is a really good choice since it has white accents and its the big brother of the all so famous and populair asus z170A. you can pair this with a galax gtx 1080 hall of fame and pick some matching galax hall of fame ddr4 ram. top that off with a 40$ white cablemod extention kit and you got yourself a pretty sollid white themed build.
for cpu cooler i'd choose the kraken x62 since its RGB (AWESOME) so you can pick whatever color you want to match with the white themed build you have.
Current Build:
CPU: Intel Core i7-7700K at 4.8Ghz CPU Cooler: NZXT Kraken X62 AIO Motherboard: gigabyte Z270X ultra gaming
Memory: Trident Z rgb 16gb 3000Mhz
Storage: Samsung 250GB SSD Storage2: sandisk ultra II 960gb SSD Video Card: Asus GeForce GTX 1080 O8G STRIX
Case: Phanteks ECLIPSE P400
Power Supply: Corsair RM650X Fans: 2x 120mm NZXT Aer rgb LEDcontroller: NZXT Hue+ LEDstrip: cablemod hybrid-LED/UV 60Cm
peripherals:
Keyboard: Razer Blackwidow X Chroma Gamepad: Razer Tartarus Mouse: Razer Mamba TE 2015 Chroma Headphones: Logitech G533 Wireless
Operating System: Microsoft Windows 10 Pro OEM Monitor1: AOC Q2577PWQ 2560X1440 OC'ed to 75 Hz Monitor2: LG 25UM57-P 25.0" 2560x1080 OC'ed to 75Hz
PCpartpicker list: https://pcpartpicker.com/list/Qt76xY
My laptop: https://www.amazon.com/Acer-VN7-571G-50VG-Notebook-Computer-i5-5200U/dp/B01CL50JV6
Quote:
If you really want it, go get it.
https://linustechtips.com/topic/725816-help-building-new-pc/#findComment-9232978
He was gonna pick the Extreme Gaming Waterforce from Gigabyte, so I went for a black and white build
idk
https://linustechtips.com/topic/725816-help-building-new-pc/#findComment-9232988
I'd suggest this:
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($344.75 @ OutletPC)
CPU Cooler: NZXT Kraken X62 Liquid CPU Cooler  ($159.98 @ NCIX US)
Motherboard: MSI Z270 GAMING PRO CARBON ATX LGA1151 Motherboard  ($164.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($106.18 @ Amazon)
Video Card: Gigabyte GeForce GTX 1080 8GB Xtreme Gaming Water cooling Video Card  ($781.04 @ Amazon)
Case: Corsair Air 540 ATX Mid Tower Case  ($139.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($88.89 @ OutletPC)
Total: $1785.82
Generated by PCPartPicker 2017-01-20 07:13 EST-0500
Cooler - NZXT Kraken X62 - looks dope and more than enough to cool an overclocked 7700k with ease.
Mobo - MSI Gaming Pro Carbon - White/Black Mobo in a White/Black case. Self explanatory. Good board overall.
RAM - Corsair LPX - It's white. 2 DIMM kits clock higher than 4 DIMM kits and you can upgrade to 32 if you feel like it.
The B2 isn't that bad of a power supply, so I'd keep it. I put the G2 in there for some reason.
idk
https://linustechtips.com/topic/725816-help-building-new-pc/#findComment-9233015
oh wow i didnt even notice that. anyways that card has some white in it as well, so black and white will be the better choice then yeah
Current Build:
peripherals:
https://linustechtips.com/topic/725816-help-building-new-pc/#findComment-9233174
52 minutes ago, Droidbot said:
I'd suggest this:
Total: $1785.82
I really like what you showed me thanks man I'll probably stick with the Dominator ram even tho its not as good I think it looks sexy as hell I'll have to look into that cpu cooler do I have to add water to it or do I use throw it in I'm kinda new to this haha
https://linustechtips.com/topic/725816-help-building-new-pc/#findComment-9233179
the kraken x62 comes pre-filled and has pre applied thermal compound on the heatsink, so you just have to install it and you are ready to go
Edited by TommyW2061
Current Build:
peripherals:
https://linustechtips.com/topic/725816-help-building-new-pc/#findComment-9233187
It's pre-filled, just install and go.
idk
https://linustechtips.com/topic/725816-help-building-new-pc/#findComment-9233193
