Complex audio sequences leveling?
Yeah, I don't really know how to word this.
Basically, I'd noticed recently while listening to music that as multiple tracks are going, or if there are vocals over a track, that one or the other will decrease in volume.
My question was essentially: Is there anything that can be done about this?
I'm not sure if my headphones just aren't the greatest for listening, or if it's like a sound design thing, or a mechanical restriction of the physical driver.
I don't know. I was just curious. =l
Thank you in advance for dealing with my stupidity.
https://linustechtips.com/topic/725759-complex-audio-sequences-leveling/
Sorry wut? I can't even. You listen to multiple songs at the same time?
Don't really understand your question here to be honest, or what you mean by 'complex audio sequences levelling'
Please explain, I am intrigued!
Does you mum know you're here?
I mean, the usual check all 'enhancement' are disabled, and play the same song from different devices to see if it's restricted to just your computer, but that just sounds like a really badly mixed song. Can you give an example of what you're listening to?
