CPU fan problem & resolution when loading game.
Hi everyone, if any of you could help me out that would be great !
So my CPU fan is spinning at 1500 RPM for some reason. I tried lowering it in bios, but unfortunately i'm quite unsure how to. I adjusted the levels for it but nothing made much of a difference, and I'm pretty sure I'm doing it wrong, so I set it back to default.
I'm using a Corsair H110 AIO with my motherboard being MSI Z97 SLI Krait.
*Edit: I checked the temps on my system and it averages at 36 - 44 C. I'm pretty sure the system isn't overheating and it does this the moment you start the computer.
On another question, for some reason whenever I load a game it changes the resolution to 256 bit colour. I went onto screen resolution -> advanced setting and brought it back to 32 bit true colour but it instantly reverts it back afterwards with just a button pressed. Tried fixing it but no idea what to do
If any of you guys can help that would be great. Thank you.
I7 4790K • Corsair H110 • MSI Z97 SLI Krait Edition • Kingston Fury Hyper X (White)(16GB)(1866Mhz) • Crucial MX 100 512 GB • Seagate Barracuda 1TB • Phantek Enthoo Pro • EVGA G2 750 Watt
Asus DRW Optical Drive • TP Link Wifi Adapter • Asus MX279H • CM Devastator Bundle (Blue) • Bitfenix Spectre Pro (White) • Windows 8.1
Galax Hall Of Fame 970
https://linustechtips.com/topic/725208-cpu-fan-problem-resolution-when-loading-game/
