Side window, Thick 280mm radiator, 2 5.25" Bays for reservoir / pump combo, thin 360mm, e-atx motherboard without motherboard overhanging rubber grommets, good cable management.
The only one I could personally find was the 750D/760T but i'd like to see if there is cheaper / better alternatives.
i7 5960X 4.5GHz @ 1.18v | ASUS X99 Rampage V Extreme/U3.1 | HyperX Predator 8x4GB 3000MHz | Titan X (Maxwell) 1480MHz/4000MHz @ 1.3v | ASUS PG27AQ
Corsair K95 RGB - MX Blue | Logitech G402 | EVGA G2 Supernova 850w
https://linustechtips.com/topic/724660-what-case-fits-my-needs/
1 minute ago, RoboTechnal said:
I have the NZXT S340 and it's perfect.
Doesn't really fit very many of my needs...?
https://linustechtips.com/topic/724660-what-case-fits-my-needs/#findComment-9219546
Just now, Crossbred said:
Corsair 750d.
Not many cheaper alternatives out there with good quality.
3600X @ stocke | 5600XT TUF OC @ 1850 | 2x16 + 2x8 RAM 3200 HD | 1tb Samsung 970 EVO Plus | Lian Li 205M | TT Toughpower Grand RGB 850 | throwaway b450 asus mobo | BQ cooler
https://linustechtips.com/topic/724660-what-case-fits-my-needs/#findComment-9221662
