Hey guys I am Ahmed,I'm 16 and this is my first PC Building I'm doing this on my own, I was trying to use pcpartpicker but for some strange reason I can't seem to find this exact motherboard which is strange, So I am posting it here :-
CPU-Intel Core i3-6100 3.7GHz Dual-Core Processor.
Link:- http://www.amazon.in/dp/B015VPX2EO/?tag=pcp03-21
MOTHERBOARD-MSI H110M-PRO-VH PLUS
(Here is the link:- http://www.amazon.in/MSI-H110M-PRO-VH-PLUS-Generation-M...)
MEMORY-(Hyperx Performance Gaming Black 4 GB DDR4 -2133 MHz) x2
(And the Link:-http://www.amazon.in/Hyperx-Performance-Gamming-Desktop...)
GRAPHICS CARD:- Sapphire Radeon NITRO Rx 460 4GB GDDR5 Graphics Cards 11257-02-20G
(The link:-http://www.amazon.in/Sapphire-Radeon-NITRO-Graphics-112...)
POWER SUPPLY UNIT:-Corsair VS Series VS550 - 550 Watt SMPS.
(Link:-https://www.snapdeal.com/product/corsair-vs-550-smps/50...)
The all total cost is $498.822 USD to be precise{ (this is too much precise I guess :)  }.
So yeah guys how's my build? any suggestion is welcomed, thank you.
https://linustechtips.com/topic/723841-my-first-pc-build/
The power supply is really sub-par, hows the price of an XFX 550w TS series, or an S12II 430b/520 from seasonic?
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/723841-my-first-pc-build/#findComment-9209987
http://www.amazon.in/RX-460-OC-Display-DL-DVI-D/dp/B01L9V9JFK/ref=sr_1_4?ie=UTF8&qid=1484577277&sr=8-4&keywords=RX+460 This is a better price for the RX460, unless you need the dual fan for overclocking room I would go with this.
https://linustechtips.com/topic/723841-my-first-pc-build/#findComment-9210005
2 minutes ago, TowerCG said:
I'd get 8 GB of RAM honestly...
he already has
https://linustechtips.com/topic/723841-my-first-pc-build/#findComment-9210011
Lose the i3 for a G4620 or 4600, since @Megah3rtz said it, a 430~500W Seasonic S series should be better, they do make really good budget units, get cheaper RAM, and i guess you should raise a bit more and get your self a better GPU
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/723841-my-first-pc-build/#findComment-9210018
